Maxthon 2.0.5.7845
Maxthon 2.0.5.7845
Příspěvek 6. listopad 2007 13:40
[Stažení programu] [Stažení češtiny]
[Nové vlastnosti]
+ Rozdělené zobrazení vráceno (klávesová zkratka F10)
+ v plugin.ini může být nastavena cesta k pluginu - pouze Button Plugin
(DefaultLocation=MenuBar/ToolBar/StatusBar)
+ Ikona pluginu podporuje formáty: png, jpg, bmp
+ vylepšené tažení v záložkách
[Změny]
* opraveny problémy s multicolor
* opraven problém s klávesou UP v adrese při spuštěném automatickém dokončování
* opraven problém s IME aplikací
* fixed problem that change to filter pack version number not work
* add confirmation when delete tab in collector
* sidebar tabs are set to show the icon only
* some skin icons updated
* the maximum number of mouse gesture action number set to 3
* site icon in tab show faster
* fixed problem that some items may not list in filtered list
* fixed an address bar display problem when tabs are opened by external program
* fixed problem that maxthon may not exit when computer is closed with "Close To System
Tray" option enabled
* fixed problem that "Enable Quick Search in Address Bar" may not work
* fixed a browser safety issue
* fixed a problem that deleting sidebar plugin may crash
* fixed problem that ">>" button of favorites bar may not work
* fixed some menu and shortcut conflict problems
* fixed drawing problem of new tab button in the tab bar;
* Favorite manager can set/unset most favorites
* fixed problem that deleted skins continue to show in Setup Center
* fixed display problem of Most Favorites which have "&" in title
* fixed crash when left click Undo menu after right click
* fixed flickering when title is clicked under "customize..." mode
* fixed some crash problems
* fixed favicon url problem (use url specified in webpage)
* fixed problem that context menu search does not work if search bar is hidden
* fixed crash when switch to different application while capturing region
